Router Telkom ADSL 5100 Problem (Or is it ISP?)
scars
Okay, since Friday, my DSL has been wacked. What happens, is, is that when there are 2 or more pc's connected to the router, I'm unable to connect to the internet, when I unplug all the network cables, except the main/server pc (the one running the 5100 configuration tool), the DSL is fine.
Sometimes, when I turn on my pc, I get a connection for about 5 secs (AIM loads and pops up the 'aim today' window), after that everything stops and the dsl doesn't work anymore.
For example, atm I'm writing this in my dad's pc seeing that it's the only one working, but when I connect another cable the DSL stops (the ADSL light is still on on the router) but I can't connect. If I connect my pc to the router, and pull out my dad's network cable, I still can't connect, it seems that my dad's pc is the only one working (Like I said, he has the router config tool on the pc).
When I go to the router configuration, all seems fine, except when I run a diagnose, I get this...
(I'm not good with routers so I dont know if this means anything, the screen was taken with only one pc connected).
*edit*
The router I.P is 10.0.0.2, and the i.p's set up on our machines is on obtain automaticaly, when I go to the Local Area network status, my dad's IP is set to 10.0.0.100, default gateway is set to 10.0.0.2 (that of the router), and mine is set to 10.0.0.101.
*update
I called my ISP and they say that my connection is working, so the only cause of this could be, is that there's something wrong on my network. What's the differnece between PPPoE and PPPoA?
sound to me like IP conflict, more than one device is acquiring the same IP address, check your settings to see if any are coming in with an address set?, did you define a network printer?
