Hi
I have a Netgear DG834GT router, running it in bridge mode, connecting via Wifi from my home pc. Have installed Raspppoe, set up 2 connections, and installed Routesentry. I have set the max conn to 2 in PPPOE properties, and when I try dial in with both connections, 1 connects, the 2nd says the modem is already in use. When I try to connect with Routesentry, it connects 1, then nothing happens. When I try to force the 2nd connection, it says Cannot connect the phonebook entry, Error 756, this connection is already being dialled. What is the problem?
When I set up the 2 connections, I selected broadband that requires password, and all is on default.
Assistance is appreciated.
