Hey guys need some help...
Ive installed everything created the 2 dail-up accounts. They show as ISDN channels, that right? They connect when I click on them and everything (Filled in password etc.)
Now when I go in to Routesentry and try to set up my routes I get this:
WebAfrica RASPPPoE -> 633 The modem (or other connecting device) is already in use or is not configured properly.
Webafrica is international, Telkomsa is local. (Im capped on TI)
Now offiously the problem here is this little line about Routesentry:
You must set the number of lines (WAN endpoints) in the PPPOE protocol properties to 2 or more otherwise you will get an error that the device is busy when you try to “dial” the second connection
Can someone just tell me how to do this? Or am I doing something else wrong?
