Routing problem to Cell-C?
ginggs
༼ つ ◕_◕ ༽つ
Super Moderator
Kapkaupunki
I'm unable to login into to Cell-C's MyTools tonight. I get an error that orion.cellc.co.za is taking too long to respond.
Code:
$ tcptraceroute orion.cellc.co.za 443
Selected device eth0, address 192.168.88.4, port 54773 for outgoing packets
Tracing the path to orion.cellc.co.za (41.50.12.26) on TCP port 443 (https), 30 hops max
 1  192.168.88.1  0.580 ms  0.322 ms  0.259 ms
 2  lac1.cpt.wbs.co.za (41.56.212.1)  47.262 ms  43.166 ms  44.830 ms
 3  vl75.cs2.cpt.wbs.co.za (41.56.254.3)  44.998 ms  42.464 ms  39.818 ms
 4  ge0-1.75.cr2.cpt.wbs.co.za (41.56.254.31)  40.075 ms  42.485 ms  44.773 ms
 5  vl75.cr3.cpt.wbs.co.za (41.56.254.36)  45.045 ms  42.776 ms  44.923 ms
 6  neotel.cinx.net.za (196.223.22.24)  44.980 ms  132.340 ms  49.760 ms
 7  41.164.0.243  45.045 ms  75.963 ms  39.815 ms
 8  * * *
30  * * *
Destination not reached
Is this a routing problem? The site works fine from another, non-iBurst, connection.
Code:
 8  * * *
30  * * *
Tx,
Will have the guys in Slaapstad look into it. CellC should be accessible via NAP.
Fixed, thanks. Guys must have finished their nap.
Code:
Selected device eth0, address 192.168.88.4, port 52045 for outgoing packets
Tracing the path to orion.cellc.co.za (41.50.12.25) on TCP port 443 (https), 30 hops max
 1  192.168.88.1  0.568 ms  0.340 ms  0.242 ms
 2  lac1.cpt.wbs.co.za (41.56.212.1)  152.064 ms  43.022 ms  39.899 ms
 3  vl75.cs2.cpt.wbs.co.za (41.56.254.3)  39.949 ms  36.995 ms  39.960 ms
 4  ge0-1.75.cr2.cpt.wbs.co.za (41.56.254.31)  49.932 ms  37.665 ms  44.868 ms
 5  vl75.cr3.cpt.wbs.co.za (41.56.254.36)  39.963 ms  43.029 ms  39.825 ms
 6  neotel.cinx.net.za (196.223.22.24)  45.001 ms  41.638 ms  44.871 ms
 7  41.164.0.243  45.041 ms  62.533 ms  44.849 ms
 8  41.160.0.242  79.715 ms  129.635 ms  64.491 ms
 9  41.160.113.28  89.953 ms  99.765 ms  80.208 ms
10  41.48.253.37  84.991 ms  109.835 ms  94.582 ms
11  41.50.0.9  79.974 ms  115.179 ms  94.517 ms
12  41.50.12.25 [open]  84.880 ms  107.371 ms  85.141 ms
In Johannesburg it is via NAP, in Slaapstad it is via Neotel!
Code:
