Digitallad
- Jun 28, 2009
Hi
Maybe some one else also had the same problem.
I recently bought a Usb TV Tunner Got the card installed , setup of the software no problems and can play my DVD player perfectly though the S video port on y laptop.
But the moment I connect my HD PVR to the card through the S video the picture goes inverted and blurry. The decoder is the only device that is giving a blurred/distorted picture my DVD player ( used to test the S Video I know I can play DVD's without the card
) is working perfectly.
It seems as if the decoder is sending out a different signal than the rest of my equipment that also have a S Video out on them.
Any one else came across this and do you have a solution?
