MyWorld
I did not need the g-sensor fix till I installed Spirit HD from the recent 10 billion download promotion on the market. The sensors would be off by 90 degrees no matter what I tried.
MAKE SURE YOU KNOW WHAT YOU ARE DOING, I TAKE NO RESPONSIBILITY IF YOU MESS UP YOUR DEVICE!
I'm a Linux boy so I had to quickly figure out how to apply the patch from within Linux, and basically you just do everything by hand that is in the script, so here goes:
1. Download the g-sensor fix -> http://www.androidtablets.net/forum...al/20304-g-sensor-fix-s7-classic-s7-slim.html
2. Extract it on your PC
It goes without saying that you should have Android SDK and Android Platform-tools installed, you can do this via your package manager.
3. cd /opt/android-sdk/platform-tools (In Arch Linux)
4. Following the script from this point on:
I will not touch that boot image yet, one of the last options in the script, since I have read some people getting some strange behaviour after a while.
And that should do it. Shout if there are any questions!
Code:
adb start-server
adb wait-for-device
adb push /*download location on pc*/psneuter /data/local/
adb shell chmod 777 /data/local/psneuter
adb shell /data/local/psneuter
adb kill-server
adb start-server
adb wait-for-device
adb shell mount -o rw,remount -t yaffs2 /dev/block/mtdblock2 /system
#Tilt fix for Noogra Nuts and Spirit HD
adb push /*download location on pc*/libsurfaceflinger.so /system/lib
adb shell chmod 644 /system/lib/libsurfaceflinger.so
#Fix for Google Sky Maps
adb push /*download location on pc*/framework.jar /system/framework
adb shell chmod 644 /system/framework/framework.jar
#SRS surround and preset equalizer fix, no idea what this does but it won't hurt trying it
adb push /*download location on pc*/libsrswowhd.so /system/lib
adb push /*download location on pc*/libaudioflinger.so /system/lib
adb push /*download location on pc*/huawei.software.srs_trumedia.xml /system/etc/permissions
adb shell chmod 644 /system/lib/libsrswowhd.so
adb shell chmod 644 /system/lib/libaudioflinger.so
adb shell chmod 644 /system/etc/permissions/huawei.software.srs_trumedia.xml
#USB host permissons, if I'm right this will allow you to connect USB devices to the tablet, I'll HAVE to test this out!
adb push /*download location on pc*/huawei.software.huawei_usb_host.xml /system/etc/permissions
adb shell chmod 644 /system/etc/permissions/huawei.software.huawei_usb_host.xml
adb shell reboot
