SA Mobile network info help please
DarrenFord
Joburg
Good day all,
I need to know technical details of what network we run on in SA for MTN\Voda
The reason is I am looking at a phone not available here and they can only advise if it will work if I provide them with this info.
Can anyone shed some light on this?
Thanks in advance..
Regards
Darren
It's easier if you mention the phone and what frequencies it can operate on and then we can assist you.
EDIT: remember that all handsets in SA must be ICASA approved.
Technical specification:
Screen:
4.3-inch E Ink® Mobius (Electronic Paper Display; 16-level grayscale)
Capacitive multi-touch (2 point touch)
Front-Light
resolution: 800 x 480 px
Battery: 1800mAh Li-ION Polymer
Dimensions: 133.6 x 70.1 x 9.6mm
Weight: 120g
Processor: Mediatek MT6515M Cortex A9 1.0 GHz
RAM memory: 512 MB
Storage space: 512 MB
Connectivity:
GSM (900, 1800, 1900), EDGE
Wi-Fi (802.11b/g/n) - Wi-Fi hotspot (via tethering)
Bluetooth 2.1 + EDR
Ports:
microUSB 2.0
3.5mm stereo audio connector
microSD port (up to 32GB)
Loudspeaker
Operating system: Android 2.3.5 (optimized for e Ink display) with wireless firmware updates over-the-air
Pre-installed apps: Search, Blacklist Number, Downloads, Clock, Gallery, Internet Browser, Sound Recorder, Email, SearchCallLog, Music, Messaging, Settings, Audio Profiles, Calculator, Calendar, Phone, Contacts, Dictionary Tool, File Manager, Android Market.
Supports: Windows, Linux, MacOS
Supported formats:
Documents and books: PDF, TXT, HTML, EPUB, CHM, PDB, MOBIPOCKET (Non-DRM), FB2, DJVU, DOC, RTF, JPD
Audio: MP3, WAV, WMA
Images: JPG, GIF, TIFF, BMP, PNG
Housing colour: black
SIM card: Full-size SIM
Vibra (e.g Vibrate on keypress)
EAN: 05901721549173
This is the frequencies from the page you linked.
Connectivity:
It should work for voice.
Surely that should be 'all handsets sold in SA must be ICASA approved'?
IIRC, importing a handset privately is fine.
