SAIX - International problems
heynnow
Having trouble connecting to international sites this moring:
Request timed out.
Reply from 74.125.95.99: bytes=32 time=494ms TTL=47
Reply from 74.125.95.99: bytes=32 time=498ms TTL=47
Reply from 74.125.95.99: bytes=32 time=495ms TTL=47
Request timed out.
Reply from 74.125.95.99: bytes=32 time=500ms TTL=47
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 74.125.95.99: bytes=32 time=493ms TTL=47
Reply from 74.125.95.99: bytes=32 time=499ms TTL=47
Request timed out.
Request timed out.
Request timed out.
Reply from 74.125.95.99: bytes=32 time=497ms TTL=47
Reply from 74.125.95.99: bytes=32 time=697ms TTL=47
Reply from 74.125.95.99: bytes=32 time=492ms TTL=47
Reply from 74.125.95.99: bytes=32 time=496ms TTL=47
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 74.125.95.99: bytes=32 time=491ms TTL=47
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 74.125.95.99: bytes=32 time=501ms TTL=47
Request timed out.
Request timed out.
Request timed out.
Local ping is relatively fine:
eply from 196.43.22.222: bytes=32 time=34ms TTL=251
Reply from 196.43.22.222: bytes=32 time=31ms TTL=251
Reply from 196.43.22.222: bytes=32 time=32ms TTL=251
Reply from 196.43.22.222: bytes=32 time=33ms TTL=251
Reply from 196.43.22.222: bytes=32 time=207ms TTL=251
Reply from 196.43.22.222: bytes=32 time=40ms TTL=251
Reply from 196.43.22.222: bytes=32 time=35ms TTL=251
Reply from 196.43.22.222: bytes=32 time=64ms TTL=251
Reply from 196.43.22.222: bytes=32 time=36ms TTL=251
Reply from 196.43.22.222: bytes=32 time=37ms TTL=251
Any1 else?
Just phoned Mweb business technical support. Voice message says that Telkom in doing maintenance on SAT-3 on the following dates and times.
Feb1 - between 2am and 8pm
Feb2 - between 2am and 5pm
All services will be experiencing connectivity problems.
One wonders why they do the maintence during work hours, surely from 5pm til 8am would be better. Most home users can live without the net for a day or 2 but business?
Can anyone suggest a ISP that does prepaid, using seacom? must have internet! ;)
Haha, cause its not their work hours..they will have to pay their employees overtime...Shame
Does anyone know if this also affects MTN and vodacom 3g ?
I think Afrihost, not Axxess prepaid. I get same problems on Axxess.
Maybe everybody should switch to Digichilli. Now is about the time you wont experience a difference in connectivity :P
They are doing maintenance during working hours because of cable breaks/inssues on SAT-3.
If the cables are broken whether they do maintenance during or after hours makes no difference. It has to be fixed immediately!
Where is the so-called redundancy? – ISP’s in this country should be sued! They overcharge and can’t seem to offer what they promise.
someone once said, the truth shall set you free... So now you are truly free.
And you are either free or you are dom....free-dom. :)
Didn't telkom say they werent investing in Seacom because it has no redundancy.. hmm.. Seacom could have BEEN the redundancy - or is Seacom down too?
Looks like whatever was broken is fixed now (Still holding thumbs it stays like this) because the internet is flying!!!
National and international sites dare I say open basically instantaneously.
