Samsung considers KitKat update for entry-level smartphones
  • Thread starter Thread starter kingrob
  • Start date Start date
K
kingrob
Guest
Samsung's plans for updating its high-end tier of smartphones have already been unveiled and we know the Galaxy Note 3, Galaxy Note 2, Galaxy S3 and the Galaxy S4 are getting Android 4.4 KitKat in January.
As it turns out, though, the manufacturer is considering also bringing the latest version of Android to its more affordable droids.
A leaked internal document shows that Samsung is investigating the Galaxy S4 mini, Galaxy S3 mini, Galaxy S Advance, Galaxy Core, Galaxy Fame, Galaxy Ace 2 and the Galaxy Fresh to see if they are capable of running KitKat smoothly.
As you might known the latest iteration of the Google OS lowers the minimum RAM requirement to just 512MB, but that's not including the custom TouchWiz skin that Samsung preinstalls on its smartphone.
Mind you, as per the leaked slide, Samsung is just investigating the compatibility and hasn't officially announced any firm plans.
Source : http://www.gsmarena.com/samsung_lowcost_phones_under_investigation_for_kitkat_update-news-7327.php
Now if Samsung decides to update the Galaxy S2 as well, I would be in absolute heaven!! :)
Can't wait for Samsung to announce it will be brought out for the S2... Just to prove what a fantastic job they did two and a half years ago.
If the S2 gets it, it would be hard for me to choose any other brand in future.
The s2 will get it :) if not from samsung, cyanogen mod will have kitkat ready to go in no time.
I think it makes it a lot easier for ROM builders/cooks to get everything working if they have a official release to dismantle.
Everything working? I tired to install a CM11 build on a S3 mini the other day -camera doesn't work on it yet.
I can't vouch for the S3 mini, but the S2's CM11 builds from Infected are pretty stable. Haven't had issues so far.
