[email protected]
I have a screen fit size issue on my Dex pad. On Android TV boxes you can simply just zoom in or out to fit device display to the TV. I in my case use a Samsung TV 40" I do not see or find a way or how to adjust screen to fit as disply is a bit too big so it cut off either sides. Dex dimply menu only show or allow for resolution.
It only had a display menu which brings up to show arrows on each to fit the screen, however, I can't find a way to do it as on the TV box which is easy you just zoom in or out to fit your screen.
I use my Dex pad with my Samsung S9+
