Samsung Digital Cam - Help?
Wino
Hi
I have just bought a DV cable to link my Samsung cam to my PC via USB.
(The Cam comes with a cable with RCA connections and one SVideo - but my PC doesnt have the necessary connections for this.)
However I just cant get my PC to recognise this USB connection at all.
I have googled all over, downloaded software etc and still no luck.
I have also downloaded "20050908173740625_MPEG4_Movie_Decoder_of_Mini_DV" - which is listed under Drivers on the Samsung web site for this cam model, but I dont know what to do with this anyway.
Does anyone know what drivers I need, any help will be appreciated.
Oops - sorry - that would help indeed:
VP-D361i
(I hope thats the right number)
Pardon my ignorance, but isn't the DV cable supposed to plug into a IEEE 1394 Firewire port and not into the USB port?
I dont know??
Does it have to plug in that way ?
This is basically my main question I suppose. Can it work via USB?
Did you get the Samsung camera with a cellphone contract? As the VP-D371i (which I have) only has a firewire (IEEE 1394) port, and once connected to the PC via a firewire card and cable (4 to 6 pin firewire cable) is identified as soon as it is switched to player mode, and allows importing of video.
Yup thats the one!
Where do I get that card and how much is it?
So it cannot work via USB - thats a definate?
Nope, no USB support on the on that comes with the contracts.
As for a firewire card, in the region of R300 when I last checked (maybe cheaper now) but well worth it. A firewire cable will set you back about R125 if you shop around (got a Belkin yesterday for R125)
I dumped some footage last night via VISTA, very easy to do. VISTA picked up the DV-Cam as soon as I connected it and was simple wizard based from there on.
From the specs on Samsungs website, it seems that it only communicates via firewire with a PC.
Specifications:
520 Line Resolution
33x Zoom, 1200x Digital Zoom
CCD 800k
LCD 112k
Colour Viewfinder
12/16b PCM Audio
Image Stabilizer
IEEE1394
AV JACK / External Mic Jack
Multi Language
Colour UV Coating
You should be able to get this at any reputable computer shop.
Here is an example of what you would need. http://www.incredible.co.za/services/catalog/moreinfo.asp?sku=59130
