dualmeister
Could be handy.
Source
Samsung Flow is a platform that enables developers to create seamless transitions across devices, so that people can change devices in the midst of an activity and continue right from where they left off.
By transferring an activity in the moment, you can use the right device for the task without worrying about the hassle of finding, starting, and navigating within the necessary application manually. With Flow you can find a restaurant on your phone, and seamlessly transfer it to your Gear S to navigate on the go.
More devices also leads to more information to track: incoming communications, alerts, updates, and more. Samsung Flow helps you track this information by notifying you across your devices. With Flow, your tablet can let you know of an incoming phone call in the living room even while your phone charges in the kitchen.
Source
