Samsung Galaxy Note 4 replacement battery
CraigS2
Hi
I'm not ready to update my Galaxy Note 4 quite yet I think. It could do with a fresh battery though. Anybody know where I can get a replacement at a decent price?
Cheers
Craig
thanks this help a lot. my Note 4 battery is just pathetic as of late. its like they make them to last only 18 months.... then again, someone told me this pathetic vodacom bloatware OTA firmware updates are to blame??? is this the case?
Weird. I'm also looking for a new battery. Does anybody know if it's possible or worth it to buy genuine replacement batteries? Mine is a year old and I want the next one to last me until my upgrade. I really don't want a generic battery that will start to lose its capacity quickly.
Mate of mine got a generic and said it totally screwed up his phone.
Would go for genuine, if possible.
I paid R500 at the Samsung store in Sandton for a new battery for my Galaxy S5 and 6 months later it's still working perfectly.
Anyone know of good Note 4 batteries with NFC?
Not sure if I want to spend the R700 odd for an original Samsung battery
Got an extended battery for Note 3 with NFC and note 4 battery from this site years ago, both worked 100%, note 3 one I used for nearly 2 years with no degrading, note 4 one less than a year before selling.
I never actually used the original battery in note 3, note 4 couple of months in I changed to a mpj
mpjbattery.com/
edit: btw, only the note 3 had the NFC on the battery, the note 4 doesn't have it on the battery, just the coils to receive the signal, the chip is on the phone
I've been having trouble with my WiFi connection recently.
Sometimes I cannot download things from playstore or surf the internet. It says no internet connection but my WhatsApp works just fine.
if I swop to mobile 3G data, internet and playstore works fine. there's some problem when I connect to WiFi.
this problem comes and goes, what's going on here?
I had a problem recently with my mobile data after being on wifi fir a long time. Tried switching to 3g, then 4g, and back to 3g with no connection.
Had to restart the phone to get it working. But it did sort itself out.
Don't know what your solution might be, hope that it didn't fall too many times, that was the problem with my previous phone, a Note 3.
Good luck and have a Yabba Dabba Doo Daa Day
