Hi all.
Does anyone know where I can get an original replacement or how to dismantle the jack of the earphones.
I have a break in the right side cable right by the jack and I have no idea on how to take it apart. The internet searches help with nothing.
I would ideally like to repair, ie unsheath the white cover from the copper jack to reveal the the soldered contact points. But problem is that I don't know if it clips off, slides off or screws off.
Failing that is there a shop that I can walk into to pick up a pair of Original Authentic note 3 earhphones.
