Basil959
- May 20, 2011
I have a PS60e550 and I use Allshare to watch series / movies and I have a few questions, I can’t seem to find an accurate answer on the net hoping someone who understands codec’s can assist?
1. I have noticed that some series in MKV have onscreen preview while other formats (avi..etc) have the generic “play triangle”.
2. I have recently got some MKV movies (H264…??) 4-7 gig and when I select them (off my PC via DLNA) the TV responds with “The selected file is not supported” and the network connection crashes, I have to “reboot” the TV before I browse the after that.
Below an example of tech info...
*Title/Year/Language.......: Safe/2012/English
*Genre.....................: Action,Crime,Thriller
*Subtitles External........: English,Romanian.
*Encoded/Profile/Level.....: 2 pass/High/Level 4.1
*Type/Codec/Writing Library: MPEG-4 AVC/H264/x264
*Container.................: Mkv
*File Size.................: 3.20 GB
*Duration..................: 1h 34mn 37sec
*Bit Rate..................: 4090 Kbps
*Bits/(Pixel*Frame)........: 0.245
*Resolution................: 1280x544 pixels
*Scan Type.................: Progressive
*Aspect Ratio/Frame Rate...: 2.35:1/23.976 fps
*Stream Video Size.........: 2.70 GB (84%)
*Stream Audio Size.........: 511 MB (16%)
*Audio/Bit Rate............: DTS/755 Kbps
*Bit Depth.................: 24 bits
*Channel(s)/Sampling Rate..: 6 channels/48.0 KHz
*Channel Positions.........: Front: L C R, Side: L R, LFE
*Chapters..................: Yes,Named
*Sample Video Runtime/Size.: 59sec/50.1 MB
*Source/File Size..........: 1080p ReMux AVC DTS-HD MA 7.1-KRaLiMaRKo = 23 GB
