Samsung S3 Mini Problem, need assistance please
ahf
Down Under
Hi All
Yesterday I downloaded Facebook and installed it from Playstore, but since then I could not open my photo gallery, and when I try to download and install other apps it get stuck say at 80% or 93% and it would not complete the downloads. I did a hard reset last night and I'm having the same problems. The other problem is I can't open my Gmail anymore. I did a virus scan with AVG mobile and it could not find any virusses.
Guys I need your expert advice on how to fix this problem
Will only be able to reply after 18:00 today.
Thanks in advance.
Uninstall Facebrook, if that doesn't work make sure your contacts are synced with Google, you backup your photos and do a Factory Reset
Also make sure your SD Card is not perhaps full
psion....Thanks, Done that and there is more than 6gb on the SD card
Update:
Resolved.
Uninstalled the latest update on GMAIL and that solved the issues on the S3 Mini.:)
