I charged my phone fully this morning and havent really used it since. Picked it up a few times for whatsapp and it felt warm and now it tells me the battery is flat. What on earth can be going on?![]()
Hey jhbgirl
Out of the box, there are quite a few things that just simply drain the battery life of the S4. Here are a few tips:
1. Try not to sync Gmail and other e-mail accounts on your device. This takes a lot of battery.
2. Turn off extra features you will not be using, such as Air View, Multi Window, Air Gesture, Smart Stay and Smart Scroll.
3. Regulate your screen brightness. This amounts for almost 40% of my battery life.
4. Activate Power Saving Mode on your handset.
Download this app from the Play Store: Easy Battery Saver
The app regulates certain features of your device in order to save on battery power. You have a number of settings or features you can choose from.
Since installing this app on my S4 I now get between 3-5 days of battery life. (I used to get around 8 hours before).
Just to note, when playing games or being on Whatsapp for some time, I also feel my battery getting tremendously warm.
