Samsung S6 issue
My_King
Residential MyBB survivor
Hi Guys,
Anyone that has experienced the following issue on Samsung S6. Original firmware.
When you check for updates the phone does nothing.
If you are lucky the update reply will pop up 4 hours later.
Same if you have a Gear S3. Galaxy wear does the same on the same phone.
Or when you go to the Google Play Store you can select an app and select to install it. The system will download the app and get stuck at 99%.
You then have to force close the app store and when you open the app store it starts installing.
Resetting the phone does not work.
My one option is to visit XDA and get firmware, but havent done that in 5 years.
Any ideas?
