BBSA
- Jul 11, 2005
- Location
- People's Republic of South Africa
Do you shower in your bedroom?My shower heats my bedroom nicely.
No 20What size/No.?
That is actually a good idea!Have a look at the sill planters made of stone - easier to fit and you could add multiple of them.
With that size pot I would say why are you not testing already ....
What time is geyser hot on an overcast day?By 10am geyser is hot. Battery is full.
Only solution for solar is more batteries.
Heat loss is what you want in this case ie if sand battery is indoors you lose nothing as that was its purpose to heat the home overnightThe actual energy you get out depends on the efficiency of the storage and retrieval process. Some energy is typically lost due to heat loss, especially when using thermal storage systems.
Sure you can use hot water at night , just have a timer on it so it doesn't heat with eskom leave it cold to heat via solar next dayI lose about 50% on rainy days. So geyser is hot by 12pm.
That is not using the battery.
Also one has to change habits.
Dont use hot water for baths in the evening.
Insulate the geyser and pipes properly this makes a big difference.
I've been thinking about using a geyser element powered by spare solar energy to heat sand in a bucket, which could then be used to warm a small room later. It sounds like a promising idea, but I'm unsure about how long the element would last under such conditions. Has anyone tried this or have any thoughts on the longevity of the heating element?
I'll check this out when winter is coming.What happened? I'm guessing the heating element housing couldn't provide enough insulation and the cable sleeving started melting?
yea geyser element is designed to be submersed if not they explode or meltWhat happened? I'm guessing the heating element housing couldn't provide enough insulation and the cable sleeving started melting?
