Sata dvd problem
Tejen
Sata dvd problem(Solved)
Im trying to install a lite on sata dvd writer and it just does not want to work.Im running xp pro and an amd athlone cpu on a gigabyte k8vm800m board.i plug in the drive and turned on the pc but it does not pick up the drive do i need to download drivers for it?
@vatso i have no problem with ide its only sata that is giving me a problem
Ok well i got the drive to work finally.I installed driver backup pro on another machine and choose to backup the sata host controller and scsi host interface controller drivers (both drivers are needed) then i installed those drivers on the amd machine restarted the pc and it was working.
