sata HDD and IDE cdrom problem, please help
wHiTe*LiGhTnInG
Durban
I cant get my cd-rom IDE to set at the last channel in my setup, wich is channel 3 i think.
it always gets put in channel 0. and my HDD's gets set to the next channels in the list.
If i unplug my IDE cd-rom, then my HDD's are set properly again channel 0 and channel 1, primary and secondary in order
When having the IDE drive set like this its causing slow downs on the system, so how can i set to cd-rom to be last in the channels. The closest i got was getting it last channel secondary, but i was missing one HDD.
help would be awsome right now.. thanks
Ok, haven't used IDE in years, but IIRC you can change the link on the drive from master to slave, that should work I think.
