I'm trying to source loose SATA power connectors, ie. those 5 pin jobbies, so I can crimp them onto an existing cable. Problem is that the modular SATA power cables that came with my Corsair PSU is for a top mounted PSU and mine is bottom mounted. This means that the "lip" of the SATA power connector is on the wrong side. Yes, I can use Molex-SATA power converters, but this will create a royal mess of cables, which I'm trying to avoid. Hence I'm looking for loose SATA power connectors. Any idea where?
