Scanner for negatives and slides
waynehooper
East London
Can anyone recommend a good scanner under R2500 for scanning 35mm negatives, slides and pictures.
I have a Canon that I bought at Incredible about 4 years back, i must have scanned more than 10 000 images ans more than 4000 slides and it is still going strong, i wil post the model when I am at work tomorrow... Think back then I paid less than a grand for it.... So Canon should be a good start...... Only thing, time consuming....
Thanks, that will be a great help.
I have been trying to get a 5600F or a 9000F, but it seems there is no stock locally. Have tried Pinnacle and a couple of other sources and no-one seems to be able to get me either.
Is there anyone lurking from Canon who can confirm stock availability...
The only ones who seem to have stock is HP with the Scanjet G5040. Anyone tried that to scan negatives?
This one is great: http://www.canon.co.za/For_Home/Product_Finder/Scanners/Flatbed/canoscan_5600F/
The 9000F is also nice but might be overkill.
I used a HP Scanjet G4010, slow going but worked great.
That's what worries me. I have heard they are really slow. The G5040 takes a heap of negatives but it looks like it will take an hour or so to scan them all...
Whatever you do, don't buy one of those little boxies that are marginally bigger than the slide/negative, which are sold by some computer stores. They are rubbish...
I've been very happy with my Canoscan 8800f. It depends what you want to do with the scans, but what you do want is a scanning density of at least 2400dpi but I'd suggest 4800dpi, even if you don't use it (that is optical, not interpolated). The end result is always better.
Finally got word from Canon that there is stock of the CanoScan 9000F MkII. Have placed an order with DCC...
I have a canoscan 8800f and love it ..
what i want is a light box .. I need it sort all my Slides and my Dads again . People dont know how to take slides out of the old cabin slide projector and tip all on the ground .
