My Dad got himself one of these cheap little Chinese scooters as a runabout, called a Kazuma I think.
Anyway, info on these things are very thin, and he has been experiencing a strange problem which he has been unable to diagnose. I should add that he is no amatuer when it comes to mechanics, so it's unusual for him to be stumped like this.
The problem exists only when the bike is hot. When cold everthing is fine, but after riding for 3km's, it feels as if the bike is "pulling back", with a loss of power.
When the bike is hot it won't start either.
Have checked the following:
Spark plug - has some oil on it but otherwise seems fine, bike isin't smoking excessively so this doesn't seem to be the problem?
2 stroke mix - the scooter has separate tanks & mixes these automatically. Also tested this by manually forcing the scooter to use only 1 tank ( manually mixed & blocked off the 2 stoke oil tank)
Rings checked & seem to be OK.
Dunno what else to check actually, but I'm wondering if incorrect valve clearances could cause this.
Any suggestions?
Any suggestions?
