Scooter Variator/belt issue
IamNoone
DRC
I have a Big Boy RCT170 scooter. The belt seems to keep getting stuck in the variator/clutch. When this happens it acts as if your car is in gear and you start it without holding in the clutch. This happens as soon as you try and pull away or rev the engine in standing. It will shudder and then stall. I have to remove the casing and reset it manually to get it to work normal again. I took it to the local Big Boy agent and they said the roller got stuck and they freed it. We replaced the whole Variator and clutch and still this happens.
Anyone have an idea?
How many kilometers?
Could be due for a belt change. They don’t last forever and wear out in due course
The belt, variator and clutch was replaced less than 250KM ago. The belt is still perfect.
