l3jorn
Hey Guys,
I've had this drive for a couple years now, but every time i installed win (i install windows on another drive (80gb WD - primary master)), it would reboot the machine on install the first time and delete the partition on the seagate, the comtinue installing windows as if nothing had happened.
This was strange, but i thought it might just be the mobo and win combo doing summing funny, so unplugging the drive on win install was the way forward from there.
Now i need to use the 80gb for another machine and tried using the seagate alone in the machine as windows drive...all goes fine until windows setup reboots the maching after copying all the files across and the damn partition is deleted again!
I plugged the seagate into the other machine and tried it...this time the partition isnt gone, BUT after restard in the win setup, it hangs on trying to boot from the drive!!
ANY ideas whatsoever? As a slave or secondary master with win running on another drive this thing works perfectly, but try to boot from it and nothing works.
Any ideas would be greatly appreciated..but please no crap like 'trash the drive and buy another', cause i really dont have the cash to buy another drive.
