Seagate Freeagent 1.5TB only read/write at 1mb/sec
NomNom
Auckland, New Zealand
So I recently bought someone an external Seagate Freeagent 1.5TB hard drive. The weird thing is it only copies and writes at 1mb/sec on his laptop on a USB 2 port, but when I connect it to my pc it copies at 30mb/sec?
I can't seem to figure this one out.. :confused:
His laptop is this one: https://www.nivo.co.za/#buy~asus.eee.pc.1201n.12.1.netbook.computer.1201n.black~p19270
and this is the hard drive: https://www.nivo.co.za/#buy~seagate.freeagent.desk.1.5tb.desktop.external.hard.drive~p13382
what seems to be the problem is that the laptop or the hard drive doesn't pick up that it's connected to a USB 2.0 port, seems like it thinks it's a 1.1 port.
Any help would be greatly appreciated. :)
Update his drivers for laptop,like his chipset drivers,uninstall usb drivers under device manager,those are things I would try,also check in his bios,if unsure in bios load system defaults in bios and see if that works,also boot laptop with external and see if that works
Downloading chipset drivers: http://za.asus.com/Eee/Eee_PC/Eee_PC_1201N_Seashell/#download
, I already installed them a few months ago, but will do it again, how do I uninstall usb drivers? BIOS is on system defaults. Not sure why I should try to boot off the external there's nothing on it.
I just tried my flash drive also, it also only copy's and writes at 1mb/sec, so it's not the hard drive at fault. Must be drivers/laptop
and the worst thing is I google these problems and can't find any answers to them :(
I was going to suggest removing the usb ports from device manager and then checking for hardware changes, it normally sorts out these hassles for me.
