Seagate Replacement PCB
iMORT3rnAL
Hey people,
I hope that someone might be able to help me. I have a Seagate Barracuda LP 2TB drive with a faulty circuit board. The drive is still under warranty, but I would prefer to get some of the data back before I send it in.
Does anyone perhaps know where I can source a replacement circuit board? Even if it's from a similar model that stopped working due to mechanical problems.
The data is NOT valuable enough to justify paying a company for data recovery.
http://techreport.com/r.x/seagate-barracuda-lp/bottom.jpg
A simple pcb swap has a very slim chance of fixing your issues.
What exactly (details) is wrong with the drive?
Yes, normally it won't be that simple, but in this case I know it will work because I've done it. I just didn't have the available space to make a backup and unfortunately the donor drive was given too someone who really needed a drive urgently.
I suspect that it's a burned IC on the board, I can smell it, but can't find any visible evidence. To my knowledge there is absolutely nothing wrong mechanically.
Hi iMORT3rnAL,
I suspect that if you replace the pcb you would have voided the warranty on the device and when you return it you may encounter problems.
Regards
Tim
If the PCB is damaged, it's 99% due to overvoltage, for example used has connected the incorrect power supply which would have voided the warranty anyway.
We offer HDD repair too, and would be cheaper than buying a new drive. The rest of the drive (apart from PCB) is most likely still perfectly good to use.
Hi iMORT3rnAL
Sound like you should be heading off to look at SOuth_Bit. But also do check the voltages that you connected before putting a replacement in .... just in case. Wouldn't want to blow another one would we?
Tim
Hi iMORT3rnAL,
Regards
Tim
Yes, I would assume that a PCB replacement would void the warranty. If it did, then so be it.
Actually, after some troubleshooting I suspect that it might be a faulty port on the motherboard.
Someone from South Bit asked for the PCB number, so I'm waiting for a quote.
Hi iMORT3rnAL
Tim
See the previous replies, the PSU tested fine.
