Setting Hylafax for Inernational Dialing
Rinkhals
Johannesburg
Hi,
I'm having a little difficulty getting Hylafax to dial International numbers.
Local works fine.
I have a feeling it must be blocked by some tellom jiggery-pokery. Has anyone been able to get it to work?
try dialling the number from your phone. If it works then the problem's with your fax, if not, check the number, especially the international format, you might have zero where you shouldn't.
No, I can dial International numbers, but with the modem speaker turned up the phone goes to engaged after the second '0'.
0,0448704589458
00,448704589458
00,44,8704589458
00,44,8704589458
In every case I get an engaged signal after the first '0'.
Sorry Gents; my bad.
I have just tried sending a fax from another phone line and it went through alright.
Must be something with that line....
