Setting up a 12V +-1kW system
Analog Revenant
Ok, so my current setup is a SPS-600 (600w inverter/charger) with 2 x Hubble batteries connected.
The SPS-600 is connected to 4 x 100w panels (parallel config), getting a good 20-24amp charge on sunny days. Then it's connected to 2 x 13V 100ah Hubble batteries also connected in parallel. So it remains a 12v system altogether.
In terms of power usage, it suits my needs 100%. I have a separate UPS cable network and plug setup running form the inverter.
The problem: The inverter is not smart enough to prioritise solar over grid power. I have to switch manually.
So I am on the hunt for a new inverter/charger setup that will prioritise the 400w solar PV I have and only use grid power when batteries get to a certain % level.
The only reason I want to go for a 1000w inverter, is for the fridge. It spikes to +750w for a few seconds at times.
I'm thinking to go Victron Multiplus (the 1kW one - https://www.sustainable.co.za/colle...iplus-1-2kva-1kw-12v-24v-48v-inverter-charger) with an additional solar charger connected to the Hubbles.. but not sure if it will work. I do not need more than 1000w at this stage, and happy with the 12v system.
Would be interested to get some ideas?
Why that inverter? At 12k it's really expensive for an 12v 1kw
For this one just hook the batteries in series
Thanks for the reply..
So the reason for keeping the batteries in parallel is for the long standby time I have currently and utilising the PV as much as possible. So 24v is not preferable at this stage.
I'm not sure if the Axpert inverters are ideal in terms of PV vs grid power management? I've read mixed reviews online - and I did consider it, hence this thread.. :)
oh - and I'm happy to spend the $ for Victron, it's about finding the ideal equipment for the specific need
The standby time will be the same in series.
24*100=2400wh, 12x200=2400wh. Plus I've been using the 5kw mecer for 2 years and it's set to use pv most of the time.
You can configure the Mecer, that victron doesn't look like it's easily configure.
Ah, I did not know that.. thanks! But is the PV 12v an issue then when looking at a 24v inverter?
You'll have to adjust that as well, might be 2 strings of 24v. As it is 4x100w panels but the panels I'm not sure you'd have to google that.
But with the 3kw you'd be able to cover your fridge and more, could even plug it into the db and power lights.
Got it, makes sense - thanks again
Normally the smaller systems tends to be off-grid
As long as your array exceeds your load it isn't a problem
The problem comes in on bad weatther days , often the cheaper axperts can't blend eskom and solar, ie it means work to manage the batteries to have shedding reserve
The victron will mean extra money for a cerbo GX shunt etc to be able to manage the battery
As long as you are fine to manage the cheaper option manually it isn't a big deal (if you are at the premises anyway)
You get cheapish solutions that has the extra benefit of remote management for the axperts
If you want less of that drama
The 3.6kw sunsynk may be a a better buy, as it is a hybrid amd software allows easier management of battery reserves for shedding
You can also add a smart switch /timer to your existent setup
ie the timer can switch off eskom supply at a time you know the solar notmally covers the load
And if the weather changes or you know load shedding is coming you can power it on via timerbor the app remotely (cbi astute range) to have eskom cover the load so the battery charging can take priority
thanks for the detailed reply!
I did have one of those timer plugs set to turn off AC charge in the morning and turn on late afternoon. BUT - the problem with this plug, is that the timer stops working when there is load shedding.. lol - so the time gets all screwed up :)
Perhaps a smart plug will work
Some analog ones lose time as they don't turn When shedding (some have battery to keep turning , but also lose time when battery goes bad)
The digital ones don't (also has battery and lose time/settings if battery is bad ) though they have a catch they don't remember last state
the smart ones also don't lose time , and you can set the state on power loss , last state or off
Thanks again for the reply!
Do you have a suggestion for a specific smart plug I can look at? There are so many, not sure if I need to look at the amp charge (most seems 10A?)
I'm maybe going to keep the current setup and see how it goes. Fridge can wait :)
don't have lots of experience with them
i have had mixed luck with these cheap 10A smart switches the one constantly loses wifi connection
and the other works perfect bought on takealot
so next time i think i will just stick with cbi astute
have installed a few as pool timers they work great once paired but for some reason pairing is always a gripe
so lately what i do is put a wire with a plug on so i can sit in the same room as the router do the pairing then fit it in its final home
and even then the pairing takes multiple tries, at least if you are right next to the router you know it isn't a wifi reception problem
just make sure to check permissions of the android app for nearby devices whichever you use
somehow the permission for nearby doesn't show a prompt and without it success won't come
this one worked ok for me for light load
But for plug i would do this one next time i buy
thanks, ja that last plug looks cool
