Setting up a 3G LAN
Avikage
Durban
Hi,
I have a Cell C 3G modem connected to my pc and i have a wireless adsl router that i used before when i had adsl. Is is possible to use this router/or any other router to allows other wireless devices(e.g cellphone) to make use of the 3G internet connection?
Would there be something that needs to be configured in the router setup?
You should be able to use internet connection sharing. You will have to disable the DHCP server on the router because this would be taken over by your pc.
I have a TP-link router. While it works perfectly I have noticed a drop in ping when running thru it. That was with only one pc connected by wire and the wireless off.
