JerryMungo
- Jul 18, 2008
Step 5 - Install and configure OpenVPN on your server
You'll have to be more specific - if you're advocating for exposing SSH, RDP, SQL Server, etc. on the web, then I'd recommend against that. Those are huge targets. If you have other ways of securing your stuff, then by all means, use it. This is one. Do your other methods allow public key infrastructure, do they allow 2 factor authentication? Those are the kind of things you can make available at the pointy end of your box/network in one easy solution with OpenVPN instead of securing every service this way - you can just use regular authentication for those.
You'll have to explain the difference between 'your server' and 'it's own server' to me. If I'm reading correctly, you're saying "why not create a dedicated server or docker instance for OpenVPN"? If I understood correctly, then by all means, whatever works for you. "Your server" in the context you're quoting is "Your openvpn server", but it could be a multi-purpose box with or without containers, etc. etc. Whataver works for you.
Not all cloud providers do, some give you little more than a virtual machine (e.g. linode)... and how it's implemented is different from provider to provider. Also, not all your services and apps are available through the AWS portal - you might be wanting to access any number of custom apps on different endpoints which Amazon is not aware of... also, some providers charge for extra security. OpenVPN can also be automated and runs on Windows, Mac and Linux. It may be a fit for you, it may not.
Look dude, let's end this pointless discussion. Not everyone uses your use cases. This doesn't suit your needs? No worries, don't use it, but quit trolling.
And while you're at it, please let Amazon know they're wasting their time marketing this crap when it's not necessary LMAO
Virtual Private Network - AWS VPN - AWS
AWS VPN establishes encrypted connections for hybrid connectivity networks with AWS Site-to-Site VPN and remote workforce access with AWS Client VPN.aws.amazon.com
