Setting up hubiC fuse mount on Debian
Mr Scratch
What?
So I have been looking for a new, cheap and decently secure backup service I can dump all my servers to and came across hubiC by OVH. It's a "cloud" based web storage service that really works for long term, incremental backups.
Link: https://hubic.com/en/offers/
NOTE: hubiC is rate limited to 10Mbit/s - if this is a big issue for you, look for something else.
Prices
25GB free
100GB 1euro/pm
10TB 5euro/pm
Help a homie out
If you decide to sign up, please use my referral code: OESJSI
Setting up a fuse mount in Debian
Firstly, go to https://hubic.com/home/browser/developers/ and create a new application. Call it something unique and use "http://localhost/" for domain redirection. Take note of the client_id and client_secret generated as we will need it.
apt-get update && apt-get upgrade
apt-get install git nano gcc make curl libfuse-dev pkg-config libcurl4-openssl-dev libxml2-dev libssl-dev libjson0 libjson0-dev libmagic-dev
cd /hubicfuse
./configure
make install
./hubic_token
client_id (the app's id): your client_id from above
client_secret (the app's secret): your client secret from above
redirect_uri (declared at app's creation): http://localhost/
Get account usage (r): r
Get all published links in one call (r): r
Get OpenStack credentials, eg. access to your files (r): r
Send activation email (w): r
Add new/Get/Delete published link (wrd): wrd
user_login: your hubiC email
user_pwd: your hubiC password
copy the client_id, client_secret and refresh_token it spits out and put it into a file called .hubicfuse in the $HOME directory of the user you will be using, for the sake of this tutorial I'll use root (don't use root...)
nano /root/.hubicfuse
Paste in:
client_id=ABC
client_secret=123
refresh_token=XYZ
mkdir /mnt/hubic
hubicfuse /mnt/hubic -o noauto_cache,sync_read,allow_other
Your hubiC fuse is now done and mounted at /mnt/hubic
I prefer syncthing - keeps all my devices in sync and is self hosted.
Hubic is more of a dropbox type replacement....
Their stuff is solid for backups though, since Amazon killed my ACD :cry:
Just Duplicity to /mnt/hubic
and you're sorted
and you're sorted
Does it still work?
just came access hubiC, and it looks great!!
anyone else using it?
will sign up for the free 25GB (will use your referral) , and will try set it up as an fuse mount on my openmedia box (Debian based).
Does it still work?
Yeah, it's still awesome :D
I am not reading good reviews....but will test it over the weekend.
if anyone wanna help with me out with more space, my referral is: MJFNTH
Most will complain about the 10Mbit cap, so use case dependent. For long term throw and forget, it works.
I was waiting for my amazon drive subscription to finish, and sign up with hubic, but i see they dont accept any more customers :-(
any other good (and cheap...) cloud storage offers?
Well, there are many to be found on LowEndTalk - but if you're keen on a dedi try Kimsufi? https://www.kimsufi.com/en/servers.xml
€4.99 for a 1TB disk on a dedicated server...
