Setting up wifi
MOwrt
In your head
Hi
I have an 8ta stick and billion adsl router with 3g failover. To set up wifi using the 8ta stick, is it as simple as plugging it into the the billion router's usb port? Would there be anything else I need to do?
I think so. I don't have one myself but I'd check out the manual if the billion came with one :)
Hi
Hi there
I also have the billion router with 3G failover. Just plugging it in wont do anything. You need to access the router's configuration page to set up the failover option, and enter the 8ta details such pin number etc.and then leave the USB modem plugged in. Also I have a problem in the past when the router did not support my particular modem. You may have to do a firmware upgrade on the router if that is the case.
