[email protected]
- Oct 13, 2016
Evening,
This is my first post so please be kind.
I am also technically and aged challenged.
I have vuma installed and am running through a Cell C package where their standard modem is supplied.
All is working well but I now want to change the modem to a TP Link Archer 7 but I have run out of knowledge.
I cannot seem to be able to configure the TP to work.
I have plugged the TP LAN/WAN port directly into the CPE, done as many setups as I can understand but no luck.
The only way I can get the TP to run is to plug it into one of the ports at the back of the Cell C supplied modem.
So - some questions please:
1- Does Cell C need to change the MAC from their supplied modem to my TP ?
2 - What are the settings that I need to have on the TP ?
3- Can I run two modems off the CPR simultaneously ? Assuming I can get the TP to work direct from the CPE ?
Thanks in advance.
Martin
Thanks in advance.
Martin
