Shader model?
You will need a DirectX 9/Shader Model 2.0 (or higher) compatible graphics card. - Crysis will run on 2 to 3 year old PCs (or even 4 year old PCs).
just googled that .... and your card only has shader model 2 :o ...... time for a card upgrade looks like bru :cool:
Shader model helps in things like HDR..
X850XT - upgrade time pal ;)
You already missed out on the 1000, 2000 and 3000 series of ATi
Ok. The thing is, say I buy a 3650, this won't be much better than my X850 I don't think... So that means I'll have to spend a bit more of course. Might go for the 9600GSO...
whats your budget?
I want to spend about R1k. But I think I'll probably buy second hand. Just had a look at PCint, and the 1950 is quite cheap. But if I get a second hand one it would be much cheaper...
