Shell Unleaded / Diesel Extra
AveshR
Hi, Did anyone try this fuel? Seems promising from the adverts that's going around...
i reckon its the same old fuel they had before.....marketing ploy. I mean really...how much CAN they change?
Just buy diesel from truck stops. They are nearly 60c cheaper per liter so fancy additives won't bother you in the slightest.
shell reckons 10% extra mileage on each tank, will try and fill up with shell on my next fill up this week
I've never really noticed any extra power or mileage from using the "better" diesel. The car does puff less visible smoke out the back though when using it, so I do, because apparently it's better for the engine i.e. less polutants, greater interval between services etc. The whole sulphur content thing.
