shut down = still power on??
tyerone
hi guys
when i shut down my pc the power stays on, monitor goes off says, saving settings, shutting down ect then monitor goes blank (no signal) ie i can open cd drive, fans going like mad inside but front light on case off, any ideas???? stays on in a way??? help please....
Maybe its like in vista where you click the shut down icon but it goes into sleep?
no running xp pro and i am shutting down checked that a million times
I'm not too sure, but can you see a break in the green wire from PSU, if that is being grounded, it won't turn off. Thats my 10 cents
I think you mean if it's NOT being grounded... hmmm.. that's weird. Could explain a problem I had the other day. Thanks!
sounds like a psu issue. One often overlooks psu's. Got power - right to go. But not always the case. Got another psu to swap & test?
If the green one touches any black one = on. Thats how you jump start them. As for the problem, i haven't a clue then
yeah - knew that. But you're a boffin for thinking of it! Must be a psu problem...
thanks guys put my old psu back in case, works fine, must be the psu then the new one, oh well....have to take it back what a mission!!! :mad:
Hmmm same happens to me, but it only happens when i have my one external hdd plugged into usb (still powered on) when i switch the pc off. It's weird yeah, but when i turn the external off, then everything is ok.
