SIERRA Wireless Model MC8790 -- Can someone help with AT commands
MidnightWizard
KZN
Hi ,
Code:
[admin@RB411u] /interface ppp-client> info 0
modem-status: ready
pin-status: no password required
functionality: full
manufacturer: Sierra Wireless, Inc.
model: MC8790
revision: K1_0_2_18AP C:/WS/FW/K1_0_2_18AP/MSM6290/SRC 2008/12/29 14:49:54
serial-number: 011955000042707
current-operator:  (unknown)
imsi: 655020002832144
access-technology: 3G
signal-strengh: -79 dBm
frame-error-rate: n/a
Have this 3G card in the Mikrotik which is working and can dial out
The card shows under ports as having 7 / seven channels
One is used for info and another for data -- there is also one used for GPS
There is a command that will show all the channels and what they are used for
However
All the ones I have been able to find do not work with the above card
Does anyone know the correct AT command to use with this card that will show this information
( what all the seven channels are and what they are used for .... )
