Silver plated speaker cable, 2.5mm diameter
chrisc
Two ± 6m lengths of German-made silver plated speaker cable
About 18 months old
Came in a reel which was used
No warranty
Have upgraded to Mogami
R2600,00
Collect in Cape Town s/suburbs or Postnet for R110,00
Oehlbach Silverline 2.5mm diameter silver plated cable. 8gm/kg 1000 silver content. 7% more conductive than copper
Twin speaker cable insulated with transparent PET daflon. This speaker cable is suitable for amplifiers up to ± 200 watts per channel. The use of silver-plated oxygen-free copper (OFC) as the conductive material produces exceptionally clear sound and helps to improve the reproduction of the treble. The cable contains 120 x ultrafine silver-plated stranded copper wires - each wire has a cross section of 0.15 mm. This design means that the cable is particularly conductive and flexible. The surface conductivity effect is enhanced through this construction
1 x 7m length and 1 x 6m length
Terminated on the source side with gold-plated banana plugs. The speaker side is bare wire which has been soldered with silver solder to prevent the ends from fraying and oxidation
30564-5526df13e978462122df488ccffcafb2.data
30565-6b83093d84162ebdf2a5f30a61a2c70b.data
The improvement in sound will give you an experience akin to an orgasm
