Simple excel formula not so simple in 2010 anymore =\
Zeus07
Good afternoon everyone
I need some advice on a problem I have. I used to take the excel spreadsheets mailed to me by my PC suppliers, and simply add a new column with a formula to add VAT and markup to the supplier's price.
That was in Office 2003. Since then I used to simply carry that forumula in sheets along over the years...
..now I've lost it.
I tried to setup this formula in 2010, but it doesn't seem to be able to take the numerous IF-THEN-ELSE that I used to use.
Does anyone know how I can do this in Excel 2010?
It used to follow a route like IF CELL > 100000 THEN CELL*1.14*1.01 ELSE IF CELL>80000 THEN CELL*1.14*1.02
and so on. I havent used the correct syntax, that's just basically to show what I used to do.
That stupid little formula saved a lot of time, as I could simply add that column, hide the cost price column and print it out.
I would be SO HAPPY if anyone could help me out on this.
This works
=IF(A4>0,"A",IF(A4>2,"B",IF(A4>3,"C",IF(A4>4,"D"))))
This doesn't
=IF(A4>0,"A",IF(A4>2,"B",IF(A4>3,"C",IF(A4>4,"D","X"),"X"),"X"),"X")
Weird. Not sure wtf is up with that. Should work according to std Excel theory.
