So my LG solardom microwave oven combo is several years old. Now ideally I would like to properly test microwave leakage with a calibrated detector but I don't have one!
So I downloaded this wifi signal strength app and measured the change in 2.4GHz wifi signal strength with the phone inside the microwave with door open vs. door closed, lying flat on the turntable and off centre to the front. (DONT SWITCH ON THE MICROWAVE!)
I also did tests with the phone lying flat on the metal turntable vs. standing upright against a short glass. Upright seemed to pick up a slightly stronger wifi signal (delta ~5dBm).
Now I would like to solicate the help of my fellow forumites. Please do the same and post your results like this:
Microwave brand and model:
Years in service:
Type of turntable: glass/metal
~Distance to 2.4GHz wifi router:
Open microwave facing router: yes/no
Obstruction between microwave and router: none/walls
Phone position: e.g. lying flat, off centre to the front
Signal strength in dBm (open door):
Signal strength in dBm (closed door):
Frequency/band: e.g. 2437Mhz
Disclaimer: DONT SWITCH ON THE MICROWAVE WITH YOUR PHONE INSIDE. SWITCH OFF AT WALL IF YOU CANNOT TRUST YOURSELF OR YOUR FELLOW MICROWAVE USERS. IF YOU NUKE YOUR PHONE/MICROWAVE/HOUSE/BODY PARTS ITS ON YOU.
Years in service:
