Sitecom modem problems
CyraxHB
I'm not that clued up on setting up an adsl modem and am having some issues with my sitecom dc-227 adsl2+ modem. I've signed up for the 4mb uncapped with mweb and they confirm the account is active.
The problem is the only place I can find to enter the settings requires me to first choose my country, and SA is not listed. So I choose britain and then choose manual setup and enter the settings.
Now when I check the stats tab is has the following.
ADSL Line Statistics
Mode G.dmt
Latency Fast
Trellis Coding Enable
Status SHOWTIME.
Power Level L0
Downstream Upstream
SNR Margin (dB) 0.0 9.0
Attenuation (dB) 38.5 27.5
Output Power (dBm) 19.5 10.5
Attainable Rate (Kbps) 4512 868
Rate (Kbps) 4064 768
K (no. of bytes in DMT frame) 128 25
R (no. of check bytes in RS code word) 0 0
S (RS code word size in DMT frame) 1.00 1.00
D (interleaver depth) 1 1
Delay (ms) 0.25 0.25
FEC 0 0
CRC 0 0
Total ES 0 0
Total SES 0 0
Total UAS 0 0
I still don't have internet access so if someone can help out that would be great.
