Skill battery replacement
Johnatan56
Vienna
Anyone know where I can find a replacement?
I found a slightly higher Ah on their site, but not finding a link to buy it anywhere: https://www.skil.co.za/skil-battery-12v-1-5-ah-nimh-2610z07800.html
I found some battery packs, but at $25-30 before shipping it's cheaper just to buy a new electric screwdriver (looking at https://www.builders.co.za/Tools-&-...dless-Drill-Driver-(18V)/p/000000000000648360 as it's 18V instead of 12V while being around R70 more than Takealot's 12V version of it, it's not going to be used often, and only for screws, never as an actual drill, have a pretty nice Bosch one from before they started dropping their quality standards).
Look at one of the battery re-packers... Uniross? Batteries Unlimited.
Thanks, will probably go past them within the next week.
