Tongs of Destiny
- May 4, 2015
Anyone ever come across sliding door wheels like this?
Can't find them anywhere to get a replacement...
105mm x 20mm
15mm wide wheels
Any ideas how I could replace them, the doors slide horrifically....
Patio Sliding Door Roller, Stainless Steel, 20kg
Length: 63mm Width: 15mm Height: 30mm Material: 304 grade stainless steel Max carrying capacity 20kg per pair Bottom single roller for aluminium door Nylon rollerwww.gelmar.co.za
Patio Sliding Door Double Roller, Stainless Steel, 50kg
Length: 63mm Width: 15mm Height: 30mm Max carrying capacity 50kg Stainless steel bottom double roller for aluminium door Nylon rollerwww.gelmar.co.za
In Cape Town, you can get the actual wheels at Stewarts and Lloyds in Wetton. You will have to remove the carrier and tap out the pin
I did a similar gate some years back and one side of the pin has a circlip in it, which was rusted solid. I just cut it off with a stainless steel angle grinder blade
Best take a sample with you, as the inner and outer diameters may not be exactly the same
You might be better off replacing this with a single wheel in a carrier. Cheaper too
