Small cable that attaches to external antenna.
theor
Anyone have any idea where I can get the little cable that attaches the USB modem to the coax on the external antenna?
Managed to break of the little connector on the modem's end....
Eish!
What a way to start the weekend!
Bad news, bud:
The tiny "ring" part of the pigtail that is stuck inside the connector on the modem prevents you from attaching a new pigtail!
It happened to me. iBurst couldn't (or wouldn't) help.
I took the modem to a jeweler. Even they couldn't get the stuck bit removed.
Modem still works. It just can't attach to any antenna anymore.
Why don't you rather spend the money on a used modem instead and have iBurst assign it to your user account?
(You can have up to two modems assigned to the same iBurst username.)
Bad news, bud:
Luckily it is just that little end that connect to the modem that broke off so using the normal flat pad antenna that comes with the USB modem so not an utter train smash just think that R 235 for a little cable is madness...
