Hi,
I want to get some smart switches installed to control my home, got a samsung smartthings hub.
The switches I am looking at are Leviton DZ15S switches, below are the ratings
Incandescent - 1800W - 120VAC, 60Hz
• LED/CFL - 5A, 600W - 120VAC, 60Hz
• Fluorescent - 15A - 120VAC, 60Hz;
8A - 277VAC, 60Hz
• Resistive - 15A - 120VAC, 60Hz
• Motor - 1/2 HP - 120VAC, 60Hz
I know RSA is 240V AC, 50Hz. So the only rating that would kinda match is 8A - 277VAC, 60Hz. I am guessing this means this switch can support a 8A Fluorescent bulb up to 277 V AC at 60Hz.
Looking at one of the power saver bulbs i have installed, it runs at 105 mA, and 110 - 240V.
So ultimately my question is will this switch be usable in RSA?
I will likely get an electrician to install them, but don't want to buy these if there is no way they would work.
thanks in advance fr any advice.
8A - 277VAC, 60Hz
