SmartBroadband Wireless from Telkom vs ADSL 10Mbps
azizarnold
Hi guys,
I'm wondering if anyone has tried or is currently using:
SmartBroadband Wireless 100GB Deal TML1508005 Huawei B593 at R999
Whats your thoughts on the Telkom deal compared to normal ADSL 10Mbps?
Alternatively would you recommend it over ADSL as it seems to be LTE which is faster?
@azizarnold
Actually I have done just that; replaced my 10Mbps ADSL line with LTE. I'm not currently located in the "official" LTE coverage but I'm very happy with the change made. I have had the 100 GB + 100GB SmartBroadband Wireless Sim-only deal for about two months now and have cancelled my ADSL + fixed line last week.
I live in the Vaal Triangle and don't seem to get the speeds that are available in Johannesburg or the other major areas, but a constant download of 35 Mbps and upload of 7 Mbps is faster than I had on ADSL. I never really had a reason to cancel my ADSL since it has always been well behaved. For the same moneys I spent on ADSL I can now have a speed upgrade of 3.5 times download and 7 times the upload. The only thing I am sacrificing on is latency; up from 20ms (local) on ADSL to about 35ms (local) on LTE. Not really into gaming, so latency is not such a huge issue for me.
The increase in upload speed was the main reason for getting LTE. Makes a huge difference on Dropbox uploads.
I use a Huawei B593 connected to an external Poynting antenna (XPOL-006) that makes all the difference. Currently on a RSSI of -66 dBm at 3.3km NLOS from the base station.
Unless the loading on the LTE system become such that speeds drop, I will keep my LTE setup.
Hope this helps you to make a decision. Best option is to first test before cancelling the hard line.
Telkom is selling the newer B315 on SmartBroadband Wireless Uncapped 1 at R599 in selected LTE areas which is, in my experience better than the 10Mbps ADSL line.
