SMATV: HD 4U decoder won't scan, not enough signal
macnab69
SOLVED
The Explora works OK, now trying to get XtraView going. Start off connecting HD decoder to satellite point. Installation Wizard starts. When it gets to Step 4: SCAN it refuses. Says signal is too poor. Only option available is Back. Can't see a way to force it to scan regardless. All I can do is go back and forth between steps 1 to 4, cannot force scan.
Surely there is something I can do to bypass the Wizard and go straight to Satellite Settings.
EDIT: After some time it suddenly decided there is signal. Busy scanning now.
