spiff
- Oct 17, 2007
Has anyone else got a series of sms's from department of transport and RTMC regarding some alleged car safety issue related to your vehicle?
Do you own a Mercedes Benz W204 ?Has anyone else got a series of sms's from department of transport and RTMC regarding some alleged car safety issue related to your vehicle?![]()
Yes I do.Do you own a Mercedes Benz W204 ?
Ok nothing on my merc, thanks.To check if your Merc really does need a recall enter your VIN here
Easy as that
Mercedes-Benz South Africa | The Best or Nothing
aftersales.mercedes-benz.co.za
I've checked with merc and nothing is been recalled on my model merc.The recall is legit.
How you get notified is in question and not much detail. If its a scam I not sure how it works, because you have to confirm with Mercedes directly.
There is a recall for the SRS(Safety) unit replacement(Airbags). I would expect Mercedes to contact you, so not sure how this SMS comes into play. Nobody contacted me. I remember it had to do with certain airbags manufactured and then my VIN number was not applicable. I had a recall on other vehicle, they just looked and said it was not applicable, so not necessarly something to be replaced.
Found this on the Twitter account. It's being done in phasesView attachment 1028004
